08-20-2022
13:09
14:54
LucioFitbit
08-20-2022
13:09
14:54
LucioFitbit
App icon has disappeared from phone
01-04-2023
16:12
10:56
01-04-2023
16:12
10:56
Hi there @GehD. Welcome to Community Forums.
Thank you for sharing this experience. I'd recommend you check you have the latest Fitbit Firmware and OS of your mobile device, then check if the app is installed on your device, if not download it from App Store or Google Play depending on your mobile device.
You can follow these steps to restart your device.
Also you can check these articles, How do I use the Fitbit app? and What should I know about using the Fitbit app on my Android phone?.
