App is showing wrong battery level
ANSWERED
Hello
I have had my Charge 3 for two weeks now and am very satisfied. But one thing doesn't work. The app does not show the correct charge percentage. Right now my Charge 3 shows that it is charged to 86% but in the app it says 19%. Otherwise, it sinks well (except it does not update sleep until after a longer period of time than other updates). Does anyone know why the app does not sync battery percentage in my app?
1 BEST ANSWER
Accepted Solutions
The Fitbit and the app can get out of step if you don't for a while as the app can only show the battery level as it was when it last synced. I would expect them to be similar straight after a sync. Could this explain what you are seeing?
8 REPLIES 8
Hi Steve
Thank you for answering my question. I did as you said and now it show the right level. I think it is strange that everything else except the battery level did sync earlier but now it has dissolved and I am satisfied.
Thanks once again
Wrong.
Synced regularly.
Displays incorrect power regularly.
Try again.
@Mdeva wrote:
Wrong.
Synced regularly.
Try again.
Sorry it didn't work for you. I don't think I'll bother trying again though.
Thanks for getting back to us and for mentioning the steps you have tried to show the correct battery level on your Fitbit App @Mdeva
As @SteveH mentioned, please try syncing your device again in order to show the correct battery level.
Keep on visiting the forums.
Synching isn’t the answer. Even multiple-synching doesn’t work.
Multiple syncing didn’t work for me either. I use the app on iPad. Closing down the app and reopening did the trick. It might be a coincidence, but I also had the device charging at the same time. Before this fix the device was showing 80% and the app 17%. Both were synced correctly at 100% after the procedure described here.Hope it works for you.
Thanks for getting back to us @Mdeva and for your advise @SunsetRunner.
What happens when you try syncing your device @Mdeva. Please try what @SunsetRunner suggested and let me know how it goes.
