06-17-2020
01:20
10:19
06-17-2020
01:20
10:19
Hello
I have had my Charge 3 for two weeks now and am very satisfied. But one thing doesn't work. The app does not show the correct charge percentage. Right now my Charge 3 shows that it is charged to 86% but in the app it says 19%. Otherwise, it sinks well (except it does not update sleep until after a longer period of time than other updates). Does anyone know why the app does not sync battery percentage in my app?
06-17-2020 01:26
06-17-2020 01:26
The Fitbit and the app can get out of step if you don't for a while as the app can only show the battery level as it was when it last synced. I would expect them to be similar straight after a sync. Could this explain what you are seeing?
06-17-2020 01:26
06-17-2020 01:26
06-17-2020 01:57
06-17-2020 01:57
Hi Steve
Thank you for answering my question. I did as you said and now it show the right level. I think it is strange that everything else except the battery level did sync earlier but now it has dissolved and I am satisfied.
Thanks once again
02-03-2022 09:42
02-03-2022 09:42
Wrong.
Synced regularly.
Displays incorrect power regularly.
Try again.
02-03-2022 10:09
02-03-2022 10:09
@Mdeva wrote:Wrong.
Synced regularly.
Try again.
Sorry it didn't work for you. I don't think I'll bother trying again though.
02-05-2022 12:27
02-05-2022 12:27
02-06-2022 04:37
02-06-2022 04:37
Synching isn’t the answer. Even multiple-synching doesn’t work.
02-07-2022 00:47
02-07-2022 00:47
Multiple syncing didn’t work for me either. I use the app on iPad. Closing down the app and reopening did the trick. It might be a coincidence, but I also had the device charging at the same time. Before this fix the device was showing 80% and the app 17%. Both were synced correctly at 100% after the procedure described here.Hope it works for you.
02-09-2022 10:17
02-09-2022 10:17
