06-30-2023 23:11
06-30-2023 23:11
I got my first Fitbit (Charge 3) and was very happy with it until it stopped displaying and responding. I tried everything from rebooting device to reconnecting to my phone. I contacted support and they gave me a 50% discount so I upgraded to a Charge 4. Now the Charge 4 had the screen come off and one cable become disconnected and I did nothing strenuous with my tracker. I never got it wet and and never showered with it even though I could have. I only used it during daily use. I contacted support and of course my tracker is out of warranty. This time they only gave me a 35% discount. After having 2 trackers fail on me due to no cause of mine, why should I buy another one. I am seriously considering something else like a Garmin or such. Can any one tell me why I should stay with Fitbit after all the troubles I have had with them.
07-03-2023 06:28
07-03-2023 06:28
I think it all depends on what you plan to use it for. For me, I migrated over to the Pixel Watch which has Fitbit integration and does everything I need it to. I can see the screen much easier in daylight and take calls on my watch without issue, both of which are critical for my job.
one cruise ship at a time!07-03-2023 09:01
07-03-2023 09:01
Thank You DramaQueenDiva, after putting money into 2 Fitbit trackers, I did not want to put more money into them and have the same thing happen again. It seems they last until the warranty runs out then fall apart. I will check it out.
Best Answer07-03-2023 09:51
07-03-2023 09:51
Actually DramaQueenDiva, I found a Fitbit Charge 5 pod only on Ebay for $50 and am going to give that a try. $50 was my limit if I got an offer from Fitbit so it works out well. My chargers and wristband from my Charge 4 should fit the Charge 5 so it is an easy swap. Thanks for the advice. I checked out the Pixel Watch and for the price and reviews I was a little hesitant.
