01-10-2019
18:02
13:05
01-10-2019
18:02
13:05
Im trying to change the auto dim, my clock face is dimming down in the daytime time instead of at night. I would like to change it but I not sure now to. Does anyone know how to do it?
01-10-2019 18:05
01-10-2019 18:05
"Auto" setting on Brightness is the way. That adjusts to ambient light, though some think it is still too bright at night.
Best Answer01-10-2019 18:05
01-10-2019 18:05
Best Answer01-10-2019 22:56
01-10-2019 22:56
@1sandy, you can adjust it on the tracker! From the main screen swipe 3 times to the left - you should get to weather and settings screen. Tap on settings - the first option is brightness. If you have it on Auto, can change it to Normal - brightness will stay the same. Hope it helps!
09-27-2020 12:29
09-27-2020 12:29
After changing my clock face, I noticed my brightness reset to "dim". This worked and was so helpful! Thanks!
