10-08-2020
10:26
08:52
10-08-2020
10:26
08:52
@aanimesh111 Thanks for stopping by!
Let me help you with your Charge 2 not holding a charge. The battery isn't replaceable but you can try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Let me know how it goes.
