Battery
My battery icon has all of a sudden gone from my charge 2  why how do I know if my battery is low when out
5 REPLIES 5
Hi @Wils778  make sure you have turned that feature on in the app. Try a restart of the device, which often helps with a glitch. Meanwhile, as long as you're syncing, you should see the battery level on your mobile device or computer.  Let us know what happens.
Stepping in the U.S.A. since September 2013. Android 14
Have done as you said it is still not on my charge 2
Sent from my iPad
From the user manual: "To see the battery screen you must turn on the battery menu item in the Fitbit app.
Have you tried that @Wils778 ?
Sorted thank you for your help😀🖐Sent from my Samsung Galaxy smartphone.
Great news @Wils778
