I am having the same problem. I have rebooted and charged the device, turned off WiFi, rebooted the phone and turned the Bluetooth off and back on, and uninstalled/installed the app again. I am beyond frustrated.
I haven’t even worn mine much until the past 2 months. Pretty pathetic if that’s the case.
Best AnswerIt can't be a lifetime thing, because I replaced my old one about six months ago and have been having the same problem for a few days now. I can get it as far as the pairing screen but after I put in the PIN it gets stuck trying to connect >_< really annoyed as the Charge 3 is absolutely rubbish and I really don't want to have to get one of those godawful smart watches, either!
I have been having the same problem since May 3rd. I have tried everything I even tried calling customer service all they did was take me through everything that I have been doing without them and I still have yet to get it to sync it just keeps spinning on pairing.
Best AnswerIt's highly likely that a Charge 3 will react the same if it's due to the app update. It's the same app for all fitbits.
Best AnswerMine is intermittently syncing, not when I try to do it there and then. Make sure you have it set so that it can run background data, and it can launch at start up and keep running etc.
Make sure that it's excluded from any battery optimiser and data saver (I had to turn my data saver off altogether this morning on Android 9 (another new update!) as it wouldn't keep my option to allow fitbit full access for some reason.
Since that, it's sync'ed twice today, even if a bit later than I wanted. Lol.
They need to fix the bug in the update asap (please).
Best AnswerDid your phone update the app the moment it was released?
Like you say, you could take back the charge 3.
I've just had the idea to uninstall the app and reinstall incase there's a conflict with old files. I'll keep you posted. Lol.
Best AnswerWell, it has sync'ed after uninstalling/installing (restarting my phone inbetween) but it wasn't immediate. I'll see how it goes. Lol.
