01-03-2022
16:45
16:01
01-03-2022
16:45
16:01
Any help with using a Bluetooth tracker to find fit bit charge 4. I can sync it but have been looking for days. It doesn't show up as charge 4 on Bluetooth finder app. Any other good apps?
01-03-2022 17:02
01-03-2022 17:02
Go to download the app.
it is free to see if it notices your tracker, then a small payment to locate.
They will refund if you cant find the tracker.
It has a graph and beeps, which corresponds to how close you are, Saved my money several times, the last time I lost in Big Lots, Opened the app and in less than 5 minutes it was in my hand.
Well worth the couple of dollars
17:13
09:26
01-03-2022
17:13
09:26
@Rich_Laue , Nice to see you here Thank you for your insights and tips.
@lslp A warm welcome to the Community! Thank you for your message. I'm glad that your Charge 4 is syncing, it means it is near you.
We recommend as Bluetooth locator app to these apps, for iPhone, try LightBlue Explorer. For Android, try Bluetooth Finder.
Hope this helps.
Best Answer01-03-2022 17:40
01-03-2022 17:40
It hasn't been finding anything labeled charge 4 but would it maybe be untitled?
Best Answer01-03-2022 18:07
01-03-2022 18:07
Wich app are you asking about @lslp
Does the app find anything
With some apps, the tracker needs to be removed from the phones Bluetooth before the app can find the tracker.
we don't know what phone, but then i'm only familiar with Android
01-03-2022 18:32
01-03-2022 18:32
I am using android. When I scan it shows 10 or so options. Most say N/A for the name. So I don't know which one is my fit bit.
01-04-2022
16:05
09:26
01-04-2022
16:05
09:26
Hi @Rich_Laue . Thank you for helping here.
@lslp Thank you for your message.
If possible please turn all the Bluetooth devices you might have in the room or near your phone , speakers, headphones, keyboards, etc.
The Charge 4 should be labeled as Charge 4 if you are using this app; Bluetooth Finder.
When you go to your Fitbit app>profile picture>Charge 4 when does it say that the last sync was successful? How much battery had the Charge 4 at that time?
Just to verify if the tracker is still on.
See you around.
