08-15-2022
07:22
14:01
08-15-2022
07:22
14:01
I've had an incident this morning, I reached into the door tray in my car door, caught my Charge 4 on the edge and the connector on yhe watch snapped completely off the mainbody of the Fitbit, so I won't be able to just fit a spare strap. Is there any repair possible?
Hi @Hammer66 there are no repairs, but Amazon carries bands which encompass the pebble portion of the Charge 4, so you could still use your device. It's called a protective cover, if you want to check it out.
Best AnswerHi @Volley8 check my post above yours - there are no repairs for these devices. There are some repair places online, but it could cost you more than the price of a protective cover band, as I mentioned above.
Best AnswerTry an encasing wristband like this: https://www.amazon.com/Jiarusig-Compatible-Silicone-Replacement-Wristband/dp/B09N283XYQ/ref=cm_cr_ar...
You will no longer have to worry about the contact snapping or becoming to loose to hold the band.
