07-30-2019
11:40
14:11
07-30-2019
11:40
14:11
My Fitbit Charge 2 is getting dirty on both sides of the Pebble or screen part of the Fitbit. Can anyone tell me the best way to clean it.
Hi @SunsetRunner
I use rubbing alcohol to gently wipe the screen of my Alta HR and did the same for all the devices I've had over the years. It works well and cleans it nicely. You can also use plain water and a microfiber cloth.
Best AnswerHi @SunsetRunner
