01-17-2019
18:59
17:54
01-17-2019
18:59
17:54
Charge 2 will not revert back to local time. Have synced when back in zone but doesn’t change time zone.
01-18-2019 07:19
01-18-2019 07:19
Welcome to the Fitbit forums @Snowbear52! Please take a look at the information in this help article: How do I change the time on my Fitbit device? In addition, try to restart your Charge 2. Just follow these instructions to do so:
1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You'll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker's display. Your Charge 2 will begin charging.
4. Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
5. Unplug your tracker from the charging cable.
Let me know how it goes!
