10-14-2018
04:31
15:03
10-14-2018
04:31
15:03
I have problems setting up my charge 3 .nothing seems to work.
I set up my device and it says it found my tracker. And it tries to connect andere then it stops....
It wants tot restart my bluetooth .that doesn't help . if I go to bluetooth settings on my phone it says it can't connect with charge 3 beceause of wrong pincode .
What do I need to do?
01-08-2019 11:24
01-08-2019 11:24
This worked, going to settings and clearing user data. I also rebooted the device from the same, "settings, about" location. I was then able to re-add the Charge 3 to the fit bit app. And it synced. I don't know how long this will last but I've been fighting with this all day! (My husband's Charge 3.) He just told me today that it hasn't been syncing since January 1. He got this for Christmas so just like many others, it worked for about a week and then quit syncing.
01-08-2019 11:27
01-08-2019 11:27
01-11-2019 10:11
01-11-2019 10:11
the steps listed by @seantnash worked for me the main difference was I did the clear user data on my charge 3
02-03-2019 07:06
02-03-2019 07:06
I have the same problem... what did u do?
02-03-2019 07:07
02-03-2019 07:07
I have the same problem... did you find a solution??
02-03-2019 07:18
02-03-2019 07:18
02-03-2019 08:20
02-03-2019 08:20
First clear user data..
Swipe left three times on the screen to get to the Settings app. About is the last one of the Settings options, with Clear User Data being the last option in About.
Then remove the device from the fitbit app.
Then remove fitbit from ur phone and remove the device from ur Bluetooth connected device list.
Then turn off ur phone
Restart charge 3 by plugging into charger and holding button for 8 seconds, until smiley appears
Now turn on phone and install app and the. Re add device.
Good luck
02-03-2019 08:22
02-03-2019 08:22
02-10-2019 18:24
02-10-2019 18:24
The same thing is happening to me. Frustrating and makes me upset and less excited about Fitbit
08-19-2020 01:36
08-19-2020 01:36
I had a problem with first sincing my device -Fitbit Charge 3 with my new phone (Moto G8 plus) after replacing my Moto G6 plus phone a few weeks back. After many frustrating attempts I removed it from the app which resulted in not being able to connect the device at all (instead of having only sincing issues). After a lot of research and frustration, many restarts of my phone and Charge 3 I found the steps described here. I have done that plus I have also uninstalled the app from my phone then downloaded it again and installed. Then I went through the steps as described here and it finally worked!! I am not sure if it would work for me as described or if the extra step of uninstalling of the app done it, will never know but I don't care, it is set up now and sincing. I hope it is going to last and unlike others have reported the issue won't return after a short time. Fingers crossed, I don't have to suffer more frustration with this. Should the issue return I would most likely ditch Fitbit and gone with a brand that is easier to work with.
12-08-2020 16:36
12-08-2020 16:36
I was on the phone with customer support last night for close to an hour & I did everything he told me to do. Nothing worked. My Charge 3 stopped syncing about a week ago. I just read this post & cleared my user data (lost 1 weeks worth of data that hadn't been synced) & it worked! I was ready to throw it in the garbage because I had lost all hope of fixing it. Thanks so much for your help Sean!
