04-05-2018
13:53
18:54
04-05-2018
13:53
18:54
Hi,
I have a charge 2 that I have had for about 2 years now and recently I purchased a bike. I cannot get the GPS tracking to work when I use the bike exercise mode.
I have checked if "Connected to GPS" is enabled for that exercise and it is.I have restarted my device and also made sure that location permissions work. GPS does work because when I use the Run exercise I get GPS data and if I go into the fitbit app add exercise and look at the tracker I have a strong GPS signal.
I have an Android 8.0 device One Plus 5. I have restarted the device and made sure that the app can run in the background which it does, but I still can't get the bike+gps working?
04-07-2018 05:28
04-07-2018 05:28
FIXED THE ISSUE!
I contacted support and well they were all pretty useless except first guy who was helpful but still couldn't solve it.
Anyway for those who have an issue on the OnePus 5 Android 8.0 (Oxygen OS 5.0.4).
Simply delete your charge 2 from the Android App (Sync any data you want before or you'll lose it!) and then re-add it.
It should then work.
Side notes
Ensure fitbit app can run in background and "GPS Connected" is enabled for bike exercise in the fitbit app under Fitbit App > Account > Charge 2 > Exercise Shortcuts.
Hope this helps someone!
04-06-2018 17:03
04-06-2018 17:03
@SunsetRunner, when you press the side button to start the Bike activity, do you see the phone icon at the top of the screen with the dashed line attempting to connect to the phone GPS? If so, does it then get a diagonal line through the phone icon?
Best Answer04-06-2018 22:45
04-06-2018 22:45
Hi no there isn't. However, if doing a run exercise there is a phone icon abd gps works fine.
Connected to gps for bike is on
Best Answer04-07-2018 05:28
04-07-2018 05:28
FIXED THE ISSUE!
Side notes
04-07-2018 07:59
04-07-2018 07:59
Hello there @SunsetRunner, welcome aboard to the Fitbit Community.
As always thank you for you help and input @USAF-Larry.
@SunsetRunner I'm glad to hear you were able to resolved the issue. In this case I just wanted to thank you for your feedback about our Customer support and for sharing your solution. I'm sure other users might find very helpful your workaround.
See you later and stay tuned if you have more questions.
Best Answer04-16-2018 06:39
04-16-2018 06:39
Hey, I’m using an IPhone 6 and getting the same issue. I have checked exercise shortcut and GPS is turned on. It’s fine when running but not working for bike
Best Answer02-13-2020 16:29
02-13-2020 16:29
How do I select 'Bike' in the 'Track exercise' screen? I only get Run, Walk and Hike options. GPS tracks route and distance etc. I enabled the Charge HR to record my stint by holding the button down till the device vibrates, as per.
