01-30-2019
19:30
17:54
01-30-2019
19:30
17:54
While at work I noticed my Charge 2 had stopped working. I figured the battery had died so once I got home I plugged it up using my wall charger hook up. After I woke up about 7 hours later, nothing. So I checked the wall plug and it worked. Tried the hold button 12 second restart, nothing. It won’t connect to Bluetooth and I’m in the middle of a weekly challenge, to which I’m in second place. Dang it! I’m trying to win!! HELP!!!!
Welcome to the forums!
Then do a Restart
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Looking forward to seeing you around the forums!
Wendy | CA | Moto G6 Android
Best AnswerI did clean the contacts with a toothpick and a cotton swab with a little alcohol on both Fitbit and charger. Nothing.
