09-02-2025
09:03
15:32
JuanFitbit
09-02-2025
09:03
15:32
JuanFitbit
Hi , I’ve just brought a Fitbit charge 2 , It has the scrolling message on the screen of www.fitbit.com/setup. I’ve downloaded the app but it won’t update, message on app says something went wrong , try again. I’ve googled and tried everything it suggests , nothings changed. About ready to throw it out the window. If anyone can help I’d be eternally grateful 😳
@Jackie19701 , a warm welcome to the Community! Thank you for your message.
If you see the message www.fitbit.com/setup. you'll need to download the Fitbit App, log in and setup the Charge 2.
I suggest you have a look at this: How do I set up my Fitbit device?
Why can't I set up my Fitbit device?
Best Answer@Jackie19701 The Charge 2 is an older model that was discontinued in 2018. There are other posts like yours in the Charge 2, Alta, and Blaze forums. These are all models from the same era. It looks like Google removed the software updates.
Can you get a refund?
Laurie | Maryland
