09-18-2016
08:25
10:26
09-18-2016
08:25
10:26
Hi, my Charge 2 won't display any excersice shortcuts. Does anyone know how to get to them? When I press the button once, the only thing that shows up is the menu with Run, Stopwatch, Relax, etc. Please help! I really appreciate it!
09-18-2016 10:08
09-18-2016 10:08
Yeah it's actually on the "run" screen. So when you get to run, tap the actual screen (not the button) and the next exercise should come up. Just keep tapping the screen to get to what exercise you want
(spent a good while myself figuring that out!)
09-18-2016 12:53
09-18-2016 12:53
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
09-18-2016 10:08
09-18-2016 10:08
09-18-2016 12:53
09-18-2016 12:53
Mike | London, UK
09-18-2016 13:27
01-16-2017 08:39 - edited 01-16-2017 12:21
Never mind.
Best Answer01-17-2017 07:09
01-17-2017 07:09
I changed myshortcuts and deleted some of them and added new ones. Now the Charge 2 only shows 3 exercises and not the others. I've synced it multiple times. Can someone help?!
Best Answer01-21-2017 19:53
01-21-2017 19:53
Me too. It was showing 7 before so looks like a new bug
01-22-2017 00:14
01-22-2017 00:14
@Powelda and @Mstiffster are one of your exercises Gulf, if so this will crash your trackers software, and you will need to remove i
01-22-2017 02:58
01-22-2017 02:58
Best Answer03-24-2017 18:06
03-24-2017 18:06
Thanks![]()
Best Answer04-03-2017 11:51
04-03-2017 11:51
This doesn't work for me. When I get on the run screen and tap, the free run just starts up. If i scroll then, it goes to treadmill or lap run. Not workout, spinning, weights, and everything else I'm looking for.
Best Answer07-16-2017 11:55
07-16-2017 11:55
Try resetting your tracker by plugging it in and holding down the button until the logo appears.
Best Answer09-09-2017 08:59
09-09-2017 08:59
I'm trying to add spinning to my exercise shortcuts. I've added it on the shortcuts menu on the phone but it doesn't appear on my charge 2. I've also reset the charge 2 whilst charging it as recommended. Any other fixes for this?
Best Answer09-16-2017 18:42
09-16-2017 18:42
Did you sync to transfer any changes to the tracker? Are you following the advice above to select your exercise?
Best Answer12-28-2017 13:28
12-28-2017 13:28
Thank you so much!!L
Best Answer08-12-2018 08:33
08-12-2018 08:33
Thank you!!! This has been driving me crazy!
Best Answer03-28-2020 11:57
03-28-2020 11:57
Ah, I see. So basically go to your FIRST exercise on your watch. Then from there, start tapping, and it takes you through all of your exercise choices. Thank you!
