09-29-2016 19:53 - last edited on 09-09-2020 10:26 by MatthewFitbit
01-17-2017 03:35
01-17-2017 03:35
01-17-2017 07:11
01-17-2017 07:11
01-17-2017 07:11
01-17-2017 07:11
01-17-2017 07:13
01-17-2017 07:13
01-17-2017 11:14
01-17-2017 11:14
01-17-2017 11:33
01-17-2017 11:33
@hayleymay1: in your case, a waist-mounted Fitbit like the Fitbit One would probably be better...
However, just because your step count gets inflated because of your line of work doesn’t mean other metrics (e.g. calories, activity graph etc.) aren’t valid. Your arms may be moving a lot, but there’s little impact, which should be reflected in calories and activity level picked up by your Fitbit. It all depends on what you want to use it for.
Dominique | Finland
01-17-2017 12:56
01-17-2017 12:56
01-17-2017 13:08
01-17-2017 13:08
I am using my Charge 2 while working at a treadmill desk so I keep it in my pocket while I am working since my hands are, obviously, on my keyboard or on my phone. When I had my Charge HR and did the same exact thing, the steps tracked beautifully. I would say the Charge 2 tracks maybe 1 out of every 10 steps if I am lucky. I use the Fitbit to motivate me and I also use it to tell me when to take a break so I do not work too long. I have been known to walk 50,000 steps in a day without thinking twice while working. I need to watch out for that but if my Charge 2 is barely tracking, I cannot tell what I am doing. I tried tech support and they told me that my Charge 2 should not work because it is in my pocket and they had had no explanation as to why my Charge HR worked so great. Unfortunately I no longer have the HR. I am about ready to return my Charge 2 and go without a Fitbit after years of having one unless someone has a solution out there. I have tried switching settings on the dominant hand and I did synch after I did that. It did not seem to help. I am open to more suggestions.
01-17-2017 13:09 - last edited on 01-17-2017 15:13 by LucyAP
You might want to try putting it on your non-dominant wrist but saying in settings it’s on your dominant wrist. Then, in the sleep settings make sure the sensitivity setting is set to ‘normal’. See if that helps cut down on arm movements counting as steps.
Rick Mathes
Moderator edit: format
01-17-2017 13:24
01-17-2017 13:24
01-17-2017 14:25
01-17-2017 14:25
@hayleymay1: just in case you’re not aware of it: it’s possible to have two Fitbits connected to the same account. In your case, you could be wearing the One (clipped to your waist, or your bra) during your working hours and your Charge 2 outside your working hours. Sleep monitoring is more convenient with the Charge 2 (which autodetects the start and end of your sleep) than with the One (with which you need to manually start and stop your sleep by pressing its button). And obviously the One hasn’t got HR monitoring, reminder to move, relax etc.
Dominique | Finland
01-17-2017 14:42
01-17-2017 14:42
I'm getting my charge 2 in the mail today and after reading these I'm getting nervous that I spent money on something that isn't going to work. Do most people have trouble with the accuracy?
01-17-2017 15:04 - last edited on 01-17-2017 15:13 by LucyAP
well here’s the thing. Yes, you want it to be reasonably accurate, but NO device out there is going to track steps perfectly and accurately all the time. None of them. In my opinion, you want something that’s going to be reasonably close, and then will be absolutely consistent. Once you get a baseline of how many steps your tracker perceives in your normal lifestyle, now you have a baselines against which you can compare days to each other. The absolute number is less important than the trend. And again, no tracker is going to get the absolute number perfectly dialed in.
I will say, after initial challenges, I’ve got the Charge 2 at a point where when I’m going for a walk, if I count off 300 steps and then see what the Charge 2 reports, it’s usually within 5-10% of that number. I’m good with that.
Rick Mathes
Moderator edit: personal info
01-17-2017 17:31
01-17-2017 17:31
01-17-2017 18:12
01-17-2017 18:12
01-17-2017 19:23
01-17-2017 19:23
I have found that all the features of the Charge 2 work in my pocket. I remove the bands and place the heart rate senscors faceing my thigh. the charge 2 picks up all movement at the waist. inclueding all dancing and walking.
01-18-2017 03:15
01-18-2017 03:15
01-20-2017 11:39
01-20-2017 11:39
@MarreFitbit wrote:It's nice to see you around the Community @beverlyc1989, welcome aboard! Great information my friend @Dominique, very helpful!
Fitbit trackers have a finely tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or doing other arm movements, a tracker on your wrist can pick up some extra steps if it thinks you're walking. Many of these situations—such as working or cooking—do include a few steps in-between stationary periods so the tracker tries to give you credit for those steps. For the vast majority of customers, the amount of stray steps accumulated is negligible when compared to the entire day. For a more technical explanation, see How does my tracker count steps?
On bumpy trails it's possible that your tracker will register steps but these should be negligible in your overall stats. If you have a tracker with multisport mode, make sure you choose the Bike exercise before starting your workout. If you're relying on SmartTrack to automatically detect your bike ride, make sure the Outdoor Bike exercise is on. (In the app, tap the exercise title and then tap the gear icon in the top right.) If your tracker doesn't offer multisport mode or SmartTrack, we recommend logging your bike ride manually to get the best calorie burn estimation. For more information see How do I track my exercise and activities with Fitbit?
If you're doing something like pushing a stroller or shopping cart, your wrist-based tracker will count your steps but the total may be slightly lower than usual.
Your tracker has been tested against driving, buses, trains, and other public transportation and should not give you extra steps when you’re traveling under normal conditions. On bumpy roads or in a car with a stiff transmission you may get extra steps. Though a few extra steps won't affect your trends, if it bothers you its possible to log a Driving activity and remove the steps from your account totals.
For wrist-based trackers, it's important to specify whether you wear the tracker on your dominant or non-dominant wrist:
- The dominant wrist setting decreases the sensitivity of step counting and should reduce any over counting of steps when your body is not moving.
- The non-dominant wrist setting increases the sensitivity of step counting and should reduce any under counting of steps. Non-dominant is the default.
In addition to dominance (right or left), Fitbit Alta also needs to know which wrist you prefer to wear the tracker on. Tracker location helps orient the screen correctly in addition to adjusting the sensitivity of step detection.
To change your settings, in the Fitbit app go to Account tab and choose your tracker at the top of the screen.
If you feel that your step count and distance are inaccurate, first make sure the wrist placement settings are correct. Next, double check that you entered your height correctly. Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How do I measure and adjust my stride length?
Hope this helps!
I have restarted my replacement Charge 2 over 50 times since I got it. If you think being off by at least 1000 steps per day is "negligible" that is the difference between making your 10,000 steps a day or not. I have seen posts where this was not an issue until this last update. Sadly, I cannot verify that as it automatically updated to 22.48.14 when I got it. I have already spoke to Customer Service and they replaced the Charge 2. If you insist that this is a tracker issue and not a software issue, please send me a second replacement but I am leaning towards it being software as I am not the only one with the inaccuracy issues.
01-20-2017 13:00
01-20-2017 13:00
MarreFitbit thanks for replying however, speaking for myself ....I have read what you wrote before in reasearching this problem in the Charge2 articles. However, it doesn't explain my problem and most of the others on this thread. Our Charge2's are not counting enough steps. It often in the 3 days I have had has not counted basic steps around my home, including going up stairs. But will sometimes count a bunch while sitting in bed and grabbing something. Actually, what MarreFitbit wrote is saying it should be accurate and it is more talking about over steps and minimal ones. I drive on normal roads in normal conditions and my Charge2 is counting steps. Fitbit is saying "Your tracker has been tested against driving, buses, trains, and other public transportation and should not give you extra steps when you're traveling under normal conditions. " sooo than why is it counting steps. If it is a software issue fix it otherwise I'm just going to send mine back. Again, if fitbit is going to advertise it's accuracy then make sure it is. THis is a lot of money for something that doesn't work right. There is no point in using it if it doesn't.
01-27-2017 03:21
01-27-2017 03:21
OK. Done this Maria. Still 20-30% lower than Fitbit One & regularly doesn't record 100+ steps while I'm walking. I organized a replacement believing the first one faulty but the new one is no better. Incidentally, my Fitbit One agrees within 5% with the Health app on my iphone.
