07-14-2019
11:12
14:35
AndreaFitbit
07-14-2019
11:12
14:35
AndreaFitbit
The top band keeps falling off the Tracker causing my Tracker to fall of my wrist. I am afraid it is going to happen when I'm over the water and I will lose/ruin my Fitbit.
07-14-2019 14:07
07-14-2019 14:07
Hi @lisamona you need to get your band replaced. It's worth it checking to see if you are under wanranty and discussing what options might be available to you with Customer Support
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer07-14-2019 14:07
07-14-2019 14:07
Tony | UK
Best Answer07-14-2019 17:27
07-14-2019 17:27
Thank you!
Best Answer07-14-2019 23:12
07-14-2019 23:12
Your welcome, do let us know how you get on.
Tony | UK
Best Answer11-03-2021 08:50
11-03-2021 08:50
The "snap in place" of the Luxe is very challenging. I bought a replacement band for mine and it took around 20 minutes to detach the original band, and then when I tried to put on the new band, try as I might, I couldn't get it to snap in. After breaking a fingernail, I gave up and tried to put the old band back on. It fell off over and over although I know there is nothing wrong with the band. Finally I heard a barely perceivable "click" and now it seems in. This is a very challenging band technology and I don't understand why in the blood heck this got past quality control.
11-06-2021 08:25
11-06-2021 08:25
This is my 2nd Fitbit Luxe. I lost one. It fell off my wrist while I was out. I thought it was a fluke. This one is doing the same thing! I have had other fitbits (Flex, Alta and Versa) and they have a secure way for the band to attach. Why did they make such a poor way for the band to attach to the Luxe?
02-12-2022 09:34
02-12-2022 09:34
Exactly! I got the gorjana band for Christmas and it kept falling off. Fitbit replaced it, but the new one is doing the same thing.
. I bought a cheap one from Amazon and it stayed on perfectly. Why would fitbit sell something with an obvious design flaw!
Best Answer05-23-2022 13:30
05-23-2022 13:30
This is happening to me too. I am on the phone now with customer support. Mostly I want this documented on their site, so if I lose it, they still need to cover it.
It doesnt matter what band I use, theirs, aftermarket, it just snaps right off, click or no click. I hope they send a new one without this problem, but it's not looking good from the replies here.
We'll see. Thanks
07-01-2022 09:13
07-01-2022 09:13
Happening repeatedly to me also. Just on one side. Spring on watch body is not longer holding. So frustrating!
