12-28-2019 16:36 - last edited on 09-08-2020 11:28 by
The charge 2 is plugged in overnight, says 100% charged. Within 30 mins it’s dead and has to be completely recharged. It’s 12 months old!
12-29-2019
09:11
07:27
12-29-2019
09:11
07:27
@Marluk Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with the battery issues you Charge 2 is showing. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
01-01-2020 22:09
01-01-2020 22:09
01-02-2020 21:09
01-02-2020 21:09
I'm having this same issue - cleaning with alcohol and restarting did help, it still won't hold a charge more than 30 minutes.
01-15-2020 12:30
01-15-2020 12:30
Still having this issue even after following this advice! Anyone?
