08-13-2019
13:21
13:47
08-13-2019
13:21
13:47
After taking my fitbit off the charger my display screen will work for 5 min before turning black and not syncing to the app. Not sure why this starting happening out of nowhere
08-14-2019
11:44
08:23
08-14-2019
11:44
08:23
@Pete79, welcome! It's good that the community is growing!
Let me help you with your Charge 2 screen not working. This could also be a battery issue so I suggest you try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
