09-28-2016
06:26
10:26
09-28-2016
06:26
10:26
My Charge 2 tracker doesn't show the phone icon when I select the activity...no gps map after workout. I've gone through all the settings on my ios phone to make sure everything is enabled but gps must be turned off in my tracker. I can only get a gps map if I manually start and stop the workout on my iphone.
Any advice?
09-28-2016 12:15
09-28-2016 12:15
Definitely - see below:
Best Answer09-28-2016 11:36
09-28-2016 11:36
Hi @Nancy_O - It sounds like you aren't connected to your phone's bluetooth. Is the Charge 2 listed under the connected devices on your phone?
Best Answer09-28-2016 12:12
09-28-2016 12:12
09-28-2016 12:15
11-04-2016 07:10
11-04-2016 07:10
I am also having this problem and have restarted my Charge 2, but it still shows no connected GPS. When clicking through the iOS settings, in my exercises, it states that "GPS will not be turned on" for walking, running, and biking. Any hints/clues? Location services are enabled for the app and my Charge 2 is connected to my phone via bluetooth (and syncs).
11-04-2016 07:21 - edited 11-04-2016 07:28
Welcome to the Fitbit Community @arbnmp, hope you're doing great! Some Charge 2 users are seeing inaccurate/inconsistent distances when using Connected GPS with Hike, Walk, and sometimes Run mode. In the meantime, I'd suggest using "Run" mode when performing any connected GPS activity. Keep in mind that I'll pass this along to our engineering team.
Thanks so much for the heads up!
Best Answer11-04-2016 07:25
11-04-2016 07:25
Thanks for the quick reply! Will do.
Cheers,
Pete
Best Answer11-04-2016 07:29
11-04-2016 07:29
Sure @arbnmp! Thanks so much for your understanding with this matter!
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Have a great weekend!
Best Answer11-04-2016 08:04
11-04-2016 08:04
11-07-2016 03:11
11-07-2016 03:11
Thanks for the heads up and your feedback in regards to the GPS functionality @VidStimac! These kind of issues were already reported to our team to get a fix soon.
Believe me, I totally understand where your concern is coming from and we are working as fast as we can so you can guys can be back on track properly.
Best Answer01-09-2017 07:30
01-09-2017 07:30
This is exactly the issues I'm having no maps, no splits and not syncing with Strava! I have just set my goal distance for 2017 and want to be able to sync with Strava for logging distance run but not able to without GPS. I am confused by your answer, as I am getting the same 'GPS will not be turned on' message when I select run. Are we are stuck with this problem until Fitbit resolve it? Disappointing as I wanted an all in one tracker that I could use throughout the day and with multiple activities. Sounds like I'm either back to running with a phone stuck in my pocket or using my Garmin!
Best Answer01-09-2017 07:39 - edited 01-09-2017 07:41
Well @Lou_D i find the title of this thread as misleading, the Charge2 doesn't have gps but uses the gps on the phone. Therefore if you want gps with the Charge2 you will need to carry the phone wi5h you.
So why does the app say gps will not work?
Is your fitbit notifacations turnrd off?
Now if you do not want to carry a phone with you, Fitbit does make a model called a Surge which has a built in GPS.
07-08-2017 08:29
07-08-2017 08:29
The thing I just discovered with my own Charge 2 was that I have to have the fitbit app open in order for the fitbit to connect to GPS. I still feel like the distance is not as accurate as when I use RunKeeper.
08-09-2017 15:04
08-09-2017 15:04
It is very frustrating that when I am connected via Bluetooth, to my iPhone, that the GPS tracking does not work at all for my runs (I'm using Charge 2). I have tried resetting my Fitbit, and deleting then reinstalling the app. Nothing works. This is the second issue I've had with my Fitbit since I bought it (Heart Rate not working properly was the first) and it's disappointing that there doesn't seem to be any viable fixes for either of these issues. I should not have to keep resetting my Fitbit to get it to work properly. It should work properly to begin with. Or don't sell it as a product that tracks your distance, pace, etc for running/walking/biking.
08-22-2017 15:25
08-22-2017 15:25
@jenmccloy while in walk/run mode you should see a phone icon on thd Charge2 this icon will tell you the status of the GPS.
A diagonal line says not connected
A dashed line to the right says searching, trying to connect.
So is it really connected.
Is the app open or at least in memory?
Cellular network enabled?
Best Answer10-19-2017 15:24
10-19-2017 15:24
Seems like a never ending thread with the same issue. I’ve been experiencing exactly the same difficulties since I upgraded from charge hr to charge 2. Unfortunately nothing has worked
new phone, new iOS, delete the app, restart Fitbit, use run mode, remove auto recognition... think I have done all the recommendations from all the moderators or from different forums. But I’ve given up, don’t know what is left to try?
However I use Runkeeper aside (never disappoints me)... apart from the gps function (which is a quite important feature)... I love the product, display, design..
10-19-2017 17:01
10-19-2017 17:01
10-22-2017 11:55
10-22-2017 11:55
Well IF they ofler me the same, I Would gladly accept the solution.
How long time do you have the warranty?
Best Answer10-23-2017 07:09
10-23-2017 07:09
Glad I’m not alone, I’m so frustrated with it. I recently upgraded to charge 2. I managed to get it to work with connected GPS once, since then nothing. Not happy.
10-27-2017 15:53
10-27-2017 15:53
My charge 2 only recently started not tracking my runs correctly... it was fine for a long time no problems be recently I have been getting a notification that I need to check my app .. done all things to try and fix .. restarting all apps and Bluetooth but nothing.. please help
