04-02-2018
02:59
18:54
04-02-2018
02:59
18:54
My app updated yesterday and my charge 2 will no longer sync. I’ve shut off my phone, shut off Bluetooth, and tried to “forget this connection “ but it don’t even let me do that since they aren’t connecting. Please help.
04-02-2018 05:26 - edited 09-25-2024 16:43
Thanks for stopping by @Crankyangel and already troubleshooting this syncing issue. Nice way to go! ![]()
Keep in mind that syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
If your device still won't sync, try these steps (even if you've already tried them):
PS: I was curious to know where you tried to "forget this connection"? Was it on the phone's Bluetooth settings or the Fitbit app?
Give this a shot and let me know how it goes!
04-02-2018 06:16
04-02-2018 06:16
THANKS for the tying to help. In my Bluetooth phone settings I was finally able to forget the connection. Then I went to my laptop and used the Fitbit Connect. It too can’t finf my Fitbit. It’s only 2 inches away, charged, and turned on. Please advise.
Best Answer04-02-2018 06:58 - edited 09-25-2024 16:43
Thanks for getting back to me @Crankyangel! Well, let's keep using only your iPhone to sync, I don't think trying to use your laptop will help now. Is that ok for you?
As was described in my last post, since your Charge 2 receives text, calendar, and call notifications, your device has a Bluetooth "bond" with the phone or tablet that sends the notifications. This bond prevents the Fitbit device from syncing with another phone, tablet, or computer. So, turn off the computer's Bluetooth for now and let's use your phone.
Since you was able to remove the tracker from your iPhone's Bluetooth settings. I'd recommend
going back to the Fitbit app, then go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below (most of them I've mentioned in my previous post, we need to make sure about that):
If you're still unable to set up, try these troubleshooting steps:
Let me know if this time you can get back on track!
02-22-2020 13:36
02-22-2020 13:36
Have had my FitBit Charge2 for about two years and it’s been an applications nightmare on both my android and iOS phone. I performed all the suggestions but there’s NEVER a PERMANENT fix. I’d consider purchasing a newer version but the problems with my current FitBit keep me from throwing away more money and precious time. So SAD! When it works, it’s great but it is short lived. Have to literally reset my FitBit Charge 2 EVERY SINGLE TIME I go manually sync. EXTREMELY FRUSTRATING AND DISAPPOINTING but it’s obvious through all the threads, FitBit would rather put money into these suggestion pages instead of fixing the problem once and for all.
