07-13-2019
08:17
14:41
07-13-2019
08:17
14:41
Looking to see if anyone has experienced this issue. Fitbit acts crazy when I sweat and drips down to the band. Also it will suddenly start vibrating and screen cycles till it dies. Finally the button on the side does not work.
07-14-2019
10:28
10:07
07-14-2019
10:28
10:07
@Bkeper, welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Charge 2 not working as it should This is odd. I suggest you try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. Clear the button area with compressed air at a distance to clear any dirt or debris from the area. After this, restart your device and see how it behaves.
Let me know how it goes.
07-14-2019
10:28
10:07
07-14-2019
10:28
10:07
