04-21-2020
08:15
09:49
04-21-2020
08:15
09:49
Updated: I was able to fix my own problem using some guidance I found on the Fitbit site. My Charge 2 was not syncing so I deleted the app and disconnected my tracker. I'm now trying to reconnect but the setup is taking forever and the "connecting to tracker" is just spinning. I've gone through the setup steps many times to no avail. I have iPhone 8+. I'm having the same problem with the my iPad Pro.
04-29-2020
12:46
07:59
04-29-2020
12:46
07:59
@TerriGIowa I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Charge 2 not setting up. You can try the following:
Let me know how it goes.
Best Answer04-30-2020 03:01
04-30-2020 03:01
I am experiencing the same problem. My Charge 2 has been syncing with my iPad for years, and suddenly it stopped yesterday. I have tried switching on/off Bluetooth, restarting the iPad, reinstalling the Fitbit App, resetting the Charge 2, and everything else that I can see in the Fitbit instructions. I also tried my iPhone, which also does not sync. I'm running the latest iPad software 13.4.1, and the Charge 2 is running version 22.58.00. The Charge 2 syncs with my Windows 10 PC OK, but I prefer to use the iPad. Any ideas?
Best Answer04-30-2020 19:47 - edited 05-01-2020 14:27
Same input for an Android device? Mine is a new Note 9. It is not connecting properly to bluetooth, and it is not reporting sleep at all
I suspect this will trace back to account changes - new email and password, new mobile device. Please provide any suggestions, so far the instructions provided here have not helped.
