02-28-2020
05:58
10:14
02-28-2020
05:58
10:14
Hi ..... I am having problems with my Charge 2. When I run it still tells me the correct time and pace as in the voice but when I check my phone it’s not showing the time,pace -and map anymore where I run . It only shows now a pic of the cal burned. Please help. I tried everything, even deleting the app and restarting it.
03-01-2020
09:03
06:20
03-01-2020
09:03
06:20
@BIrgit5 Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Charge 2 not recording your run maps. This is done via your phone as the Charge 2 doesn't have a GPS chip. The feature is called Connected GPS and you can read how it works here. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
03-02-2020 18:25
03-02-2020 18:25
Hi
i have same problem. Tried all the fixes suggested many times. Nothing works. This has only happened since latest updates. Up to this problem I was very happy with my Charge 2. I am about to get a new device but if this is not fixed I will have to go to another brand. Please fix with urgency. 3rd Mar 2020.
