01-05-2019
10:02
18:22
01-05-2019
10:02
18:22
I couldn't find the charger for my charge 2 so the battery died. I found it about a week later and charged it. But it is showing the date the battery died and not the current date. It won't sync to my app and the app still shows an empty battery. I tried turning off/on bluetooth, restarting the charge 2, uninstalling/reinstalling the app. I even removed the charge 2 from paired devices on bluetooth and now bluetooth won't connect to the charge 2 saying my device isn't on. How can I fix this so my charge 2 will sync and I can use it again?
01-05-2019 18:29
01-05-2019 18:29
Did you follow the instructions to "re-pair" your Charge with your Phone?
It worked for me after allowing mine to sit around for a couple weeks.
