11-21-2020 22:35
11-21-2020 22:35
My new Charge 2 is not tracking stairs. Anyone know how to get it to track?
11-22-2020 04:15
11-22-2020 04:15
It should automatically track stairs - there are no options to turn tracking on or off.
It can be a bit fussy about tracking them though. Your flight of stairs needs to be at least 10 feet high and, when going up, you need to keep walking - if you pause then it cancels that flight. Could it be that your stairs are not quite high enough?
11-22-2020 11:04
11-22-2020 11:04
11-22-2020 23:43
11-22-2020 23:43
Fitbits check for altitude gained by detecting changes in air pressure via a small hole in the case. If this becomes blocked then it can stop stairs being tracked. However, as the fitbit is new it's more likely that its just defective. Are you able to return it to the retailer for an exchange? If not, then it will still be covered by Fitbit's warranty and you can make a claim via customer support: contact.fitbit.com
