09-04-2020
19:59
09:08
09-04-2020
19:59
09:08
For the last 2 weeks I've only been getting basic sleep data. No sleep stages or sleep score anymore. Nothing in my habits have changed. App update break it? Tried restarting device, toggled heart rate tracking off and on again. Nothing fixes it.
09-06-2020
12:22
05:09
09-06-2020
12:22
05:09
@jlspahn It's great to see you in the Community!
Let me help you with your Charge 2 only showing basic sleep data and thank you for troubleshooting this issue. You may not get sleep stages for the following reasons:
Still I also suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off again (after having clean the back), save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Best AnswerThanks for the reply.
All of your first items are more or less irrelevant. Ive had consitant sleep stages and score readings for over a year. Nothing has changed in how I wear my device or in my settings.
I did try the rubbing alcohol as suggested and that seemed to make no difference still.
