01-10-2018
22:55
18:54
01-10-2018
22:55
18:54
Had the charge 2 since July and it has worked fine till the last few weeks. Suddenly it has stopped recording my sleep properly. It picks up my sleep but only from a few hours after I've gone to bed. For example last night it started recording sleep at 2am when I was in bed and asleep from around 1130pm. Last week it did this on 2 nights when it started recording my sleep from about midnight/1am when I had gone to bed at 10pm. I have restarted the device a number of times, changed the sleep settings, reconnected etc. But it is still happening. I am not sure why it has suddenly started doing this.
01-31-2018 07:53
01-31-2018 07:53
Hey @KateH123, it is great to see new members around!
I appreciate the time you have taken to make your Charge 2 track your sleep more accurately. Since your sleep is not being correctly tracked, I'd like you to take the following into consideration that might be affecting your sleep data:
Wear it for a few nights and let me know if that works!
Best Answer01-31-2018 17:55 - edited 01-31-2018 21:53
Hi KateH123,
A few Charge 2 owners are experiencing similar sleep monitoring issues such as yours in the Fitbit Charge 2 tracking sleep like a flex thread.
Might want to check out the workarounds mentioned in the thread as well as what been mentioned by the moderator (HeydyFitbit).
This appears to be an issue with the latest firmware that's made the Charge 2 go wonky without much rhythm or reason. Until Fitbit fixes these bugs, we're all in the beta testers club for the time being.
01-31-2018 21:21
01-31-2018 21:21
Not sure why it is saying solved when it isn't. I tried to unclick the solved button and it automatically recorded it as solved! A bit naughty that it works that way. Thanks for the link to that thread Steve. At least I am not alone!
01-31-2018 21:25
01-31-2018 21:25
Thanks for getting back to ms Heydy. I have tried all those steps before. It is a sporadic thing and I am doing nothing different on the nights it works vs doesn't work but I will let you know if it fixes itself!
Best Answer01-31-2018 22:13
01-31-2018 22:13
The correct message form @HeydyF would have been:
Hi @KateH123, we have noticed that more customers are experiencing this problem. Please have a look around for the other topics for some tips to overcome the issue. You could for example try to wear your Charge a bit higher on your arm or use the sleep now function in the app.
Meanwhile we are investigating what is causing these sudden issues. But that means that our developers should actually look at a finished product and I don't expect many results since most feature requests are open for 2 years+, when you will not be owning our product anymore anyway.
Best Answer02-01-2018 00:00 - edited 02-01-2018 00:20
Hi LinkeLoutje,
Think we all know the frustration of working with buggy firmware. If no one has said so -
welcome to Fitbits' beta testers club! While being a beta tester, you get to discover all sorts of issues and problems associated with buggy firmware from Fitbit.
To join the beta tester club is quite easy - there's a cost, so best to be up front about it. Simply purchase a Fitbit device and install the latest firmware.
As you're discovering issues, you will go through many hair pulling moments and bouts of madness. When this happens, take a break with your favorite beverage and/or go outside for a breath of fresh air. Your Fitbit device will be okay as bugs will continue to be there - so don't worry. It'll be right where you previously left it and looks forward in going through another roller coaster ride with you - when in the mood.
There maybe an ahah moment! That's when you discover a workaround to the issue at hand. It will most probably be an unsatisfactory solution (i.e PITA), but Fitbit appreciates you posting results on the forum so others may try it and see if the workaround covers up the bug. Unfortunately you wont get paid for the time and effort of discovering the workaround. At best get a few +1 thumbs up from fellow community members.
Once again, thank you for being part of Fitbit's beta testers club! Hope you have a nice day.![]()
02-01-2018 09:02
02-01-2018 09:02
Thanks very much @steveting99! Glad you took the liberty to welcome me to the club, since we all know that such a gesture and actually showing interest in a customer is not part of @HeydyF's script.
Best Answer08-15-2018 05:45
08-15-2018 05:45
Hi all new to Fitbit and I must admit the sleep analysis is pretty poor. Says I’m I bed at 3am when in fact I’m in bed at 10:30pm. Brand new Fitbit Charge 2. I use the app to tell me when it’s time to sleep. Other apps appear to work fine.
Best Answer05-15-2019 11:52
05-15-2019 11:52
I have exactly the same problems. I’ve done everything that Fitbit have told me to do and it’s done nothing at all. SO FRUSTRATING!!!
