09-19-2020 15:07
09-19-2020 15:07
My Charge 2 has not synced for 5 days. Have tried resetting device 3 times, have uninstalled and reinstalled the app which didn't help. I have now unpaired the Bluetooth connection but it will not now pair again. Any suggestions how to fix ?
09-22-2020 03:56
09-22-2020 03:56
No idea my weekly reports are all wrong! Wish someone would help!
09-22-2020 07:36
09-22-2020 07:36
I am having the same problem. It shows low battery when fully charged and won't sync. I know there was once a 'sync now' option but I can't find it anywhere.
09-22-2020 07:59
09-22-2020 07:59
i have the same problem
09-22-2020 08:43
09-22-2020 08:43
Update
I have been in touch with fitbit support who have only so far suggested I try all the things I have tried but waiting on further advice from them so hopefully will get this resolved.
09-22-2020 08:58
09-22-2020 08:58
try customer service 877-623-4997, they helped me in 14 minutes.
09-22-2020 09:31
09-22-2020 09:31
Do yourself a BIG favor and throw the thing in the garbage.
I have had a Fitbit for over 6 years and have finally become frustrated to the point of no return.
I bought a brand new Charge 3, got it yesterday. It won't sync properly, I can't change the clock faces and the apps do not work at all.
Going to return the Charge 3 for a refund. I can no longer get my Charge 2 to link to my phone or my computer; it never would link properly via Bluetooth. Totally frustrated, done with Fitbit.
Have fun!!
09-22-2020 10:00
09-22-2020 10:00
I still have the sync now option but it doesn't sync anyway. 🙁
09-22-2020 10:02
09-22-2020 10:02
Thanks. I'm in UK and there doesn't seem to be any contact numbers here. I'm hoping to get a solution though via fitbit support.
09-22-2020 10:05
09-22-2020 10:05
I've had fitbit for 4 years with no problems until now. Hoping to get a solution but if not will have to consider moving away from Fitbit to another brand.
09-23-2020 02:17
09-23-2020 02:17
Mine crashed this morning. The app won’t work on my iPad either. Makes me cross that these companies don’t support their old products. The one I have worked fine. I don’t need new crap.
09-23-2020 15:39
09-23-2020 15:39
Same has happened to my charge 2.
Suddenly it won't sync, and it makes me mad.... Don't know how to fix it...
09-23-2020 16:07
09-23-2020 16:07
My charge 2 won't sync on it's own or when I "sync now". No issues until the last few days. Super frustrating!
09-24-2020 01:57
09-24-2020 01:57
The problem with syncing my charge 2 started on September 9th. After I purchased free trial on fitbit premium in the app... 🙈
Any tip on how to make it sync again?
09-24-2020 09:17
09-24-2020 09:17
My Charge2 will not sync and the screen won't activate/turn on.
09-25-2020 13:50
09-25-2020 13:50
I have to exit the Fitbit app, go into iphone general settings to turn bluetooth off and then back on. Then it will sync. I HAVE TI DI THIS EACH FRIGGEN TIME.
Fix the app!
09-26-2020 01:40
09-26-2020 01:40
Even this doesn't work for me. I know the issue is with a recent update to the app but Fitbit insist it's my device and I should buy a new one. 😒
09-27-2020 09:28
09-27-2020 09:28
I started having problems with my Charge 2 a while ago, mostly it wouldn't sync.
So I decided to try a Charge 3...
It was a bit tricky to get it set up, but now that it is I have to say that I am very pleased with it.
So far, it's the best tracker I have ever had.
(Good on you, Fitbit!!)
09-28-2020 12:34
09-28-2020 12:34
I've been having this issue for over a year now with my charge 2 syncing sporadically making me miss up to an entire month a couple times. I don't always look at the app but expect it to work when I do as it's meant for tracking your stats. The latest is that it's been 5 days since it synced and now when I do it manually I'm getting an error message saying that it can't, but no clue as to why. I can't afford a new one and the idea of making an app not recognize widely used products just to make people throw them away, adding to the massive garbage problem helping to kill our environment just so Fitbit can make more money selling the newest stuff every year is reprehensible. Fix this issue, NOW or lose a lot of customers. I bought this just 2 years ago expecting it to work for much longer. It does still work just fine. Its the app that's broken. It's so often broken it's highly annoying and I'm sick of it. Without the app, these devices aren't worth a thing. I have my charge 2 set to sync always because I don't use my phone much and want it to sync whenever it can. But it won't even sync now when the phone is held in the same hand that the Fitbit is on so it's only a couple inches away and I don't do anything else while it's trying to sync, and it won't. Not a happy customer.
09-28-2020 15:41
09-28-2020 15:41
Your right, its too confusing and does not sync properly most of the time. Must be made in China which is another reason to toss it.
