10-07-2016
16:59
10:26
10-07-2016
16:59
10:26
04-02-2017 14:44
04-02-2017 14:44
If your Fitbit is connected to your phone and you're still not receiving notifications... You have to hold the button down on the side of the Fitbit itself. It's a silence feature that has to be turned off.
04-02-2017 14:45
04-02-2017 14:45
Hold the button on the Fitbit itself. The Fitbit comes silenced. If you sold it down for 3 seconds it will turn the notifications on.
04-02-2017 20:00
04-02-2017 20:00
Informational:
My text and call notifications were working great for 5 months and then all of a sudden stopped working. I checked all the settings on my phone and they were all still turned on. So I started playing wit's my actual watch...turns out if you push and hold the side button of the watch the notifications will turn off/on. Which means one of my kids must have been playing around with it.
04-03-2017 10:50
04-03-2017 10:50
I wore the Charge 2 for about 6 months, everything worked great. I recently ordered and received the Alta HR and decided to gift my husband with my Charge 2. I cannot get the call/text notification to work.
Here's what I have done:
delete and hard reset the whole thing
delete the app from the IPhone 7plus or whatever the latest big monster is
Disable call notification and restart on the Fitbit itself (hold the button for 3 sec)
disable bluetooth, turn the phone off, turn BT back on
redown the app and pair the C2 MULTIPLE TIMES
Made sure to remove any other Fitbit tied to his phone (the only thing left paired is the Aria)
Every single suggestion on all of these 6 pages, I've done over and over and still, call/text notifications will not work.
Any other suggestions?
Best Answer04-03-2017 11:40
04-03-2017 11:40
Just hold down the button on the Charge 2 and it will come on
04-03-2017 13:49
04-03-2017 13:49
What about using a Samsung Galaxy S7 active? Are the steps the same?
Best Answer04-03-2017 15:18
04-03-2017 15:18
Hold the button on the Fitbit itself for 3 seconds.
04-03-2017 18:52
04-03-2017 18:52
I have the same issue with charge 2 with ip phone 6s. I'm unable to received phone call or text message . I have tried to the steps posted by remove fitbit app and re-add with new pin. But it doesn't work. Bluetooth able to connect charge2 , charge2 is synced with fitbit app. I also tried reboot Apple phone too. Though all of that, it still doesn't work
Best Answer04-03-2017 21:44
04-03-2017 21:44
04-04-2017 16:36
04-04-2017 16:36
Thanks. I just realised my new Fitbit was not alerting me to calls and emails, which I found very helpful with my previous one.
Best Answer04-04-2017 16:41
04-04-2017 16:41
Thanks. Figured it out. Hold down the switch till it comes up as notifications are on.
04-05-2017 12:49
04-05-2017 12:49
My fitbit works fine except for the notifications everything has on on my phone and I followed the steps above and it still doesn't work. I have never had problems with my fitbit until I owned a charge 2
Best Answer04-05-2017 14:18
04-05-2017 14:18
Thanks . I got it worked by turn on notification on fibit
04-06-2017 00:55
04-06-2017 00:55
@Sherry have you checked your phones notification center to make sure that Fitbit has permission to send notifacations? This is one of the things listed to check.
@ltaylor90, I'm not sure what steps you have tried, or what phone you have?
04-06-2017 03:21
04-06-2017 03:21
Best Answer04-07-2017 07:33
04-07-2017 07:33
@ltaylor90 did you try @Walt001's suggestion above
04-07-2017 08:29
04-07-2017 08:29
04-07-2017 11:05
04-07-2017 11:05
Awesome that worked thank you!!!
04-10-2017 10:09
04-10-2017 10:09
Thank you - that worked and I had tried several other
@wmchapman wrote:Text and call notifications require pairing @evance1024
On your 6s go to settings, scroll way down to applications, touch fitbit then notifications, make sure notifications are "on". Go to bluetooth and "forget this device" (circle i for dialog) any trackers connected. Return to the home screen and hold any app icon until they all wiggle. "x" (delete) the fitbit App. Use the Safari browser to go to fitbit.com/setup and download the App, follow the guidance for "add a new device with an existing account." Come back and let us know that when you got to the 4 digit code pairing the first time it was a success so we can pass this advice forward 🙂
fixes - Thanks again!!
04-10-2017 14:30
04-10-2017 14:30
Tried everything in this post. Resetting/unpairing/re-enabling, etc...and yes, the Charger 2 itself has notifications turned on (hold button for 3 sec)...still not getting text notifications. Just buzzes when incoming call. Only had it two days or so...nothing's changed since initial setup. BTW on an LG V10 the battery dies fast when syncing all the time.
