10-03-2016 15:44
10-03-2016 15:44
10-03-2016 15:56
10-03-2016 15:56
@Ashley1599 Welcome to the Fitbit Community, you can totally add "Walk" to your Charge 2's exercise shortcuts. Click here for instructions on how to add exercise shortcuts to your Charge 2.
Let me know if there's anything else that I can do to help!
10-03-2016 15:56
10-03-2016 15:56
10-03-2016 19:49
10-03-2016 19:49
Best Answer10-03-2016 19:57
10-03-2016 19:57
Best Answer04-04-2017 14:41
04-04-2017 14:41
I followed the tips from the link you included, I don't have an add icon on my exercise shortcuts screen. Any other suggestions?
04-04-2017 14:54
04-04-2017 14:54
@SunsetRunner, do you already have 7 exercises in the Exercise Shortcuts? If so, you must delete one before you can add another - 7 is the maximum number of shortcuts you can have.
If you do not have 7 shortcuts, you should see a line at the bottom of the Exercise Shortcuts that you can click to add one or more, such as in this screenshot:
04-04-2017 19:56
04-04-2017 19:56
Thank you! What an easy fix!
Best Answer05-11-2017 07:03
05-11-2017 07:03
How do I add "Walk" to my fitbit charge 2
05-11-2017 07:06 - edited 05-14-2017 09:20
@tomwlane please scroll up and follow @USAF-Larry's post above, it is two posts above yours. https://community.fitbit.com/t5/Charge-2/Charge-2-tracking-gps-walk/m-p/1918148/highlight/true#M4130...
You may also go to the Fitbit Hrlp doc that @DerrickS points to in the second post.
Best Answer05-14-2017 08:15
05-14-2017 08:15
Walk doesn't appear to be one of the options.
05-14-2017 09:22
05-14-2017 09:22
@Jayabalard please see the accepted solution by @DerrickS above, or @USAF-Larry's post above, It is the post that I linked to in my last post that you responded to.
Best Answer07-01-2017 07:49
07-01-2017 07:49
I don't have a walk option to choose. Can I add it?
Best Answer07-01-2017 07:59
07-01-2017 07:59
Walk is not an option on my Fitbit watch, it does show on the tracker on my phone, also can't figure out how to activate gps.
Best Answer07-01-2017 08:03 - edited 07-01-2017 08:47
Walk is not an option on my Fitbit watch, it does show on the tracker on my phone, how do I get it on the actual device? Also, can't figure out how to activate gps. Settings on phone has locator turned on for Fitbit app. Can't find anything in app to turn it on.
Sorry for two comments, got an error saying the first did not post.
Best Answer07-02-2017 01:14
07-02-2017 01:14
Hello @LeeR315 please scrol up the page to the accepted solution where you will find a link to the instructions. Or look at @USAF-Larrry's post with his great screenshots
Best Answer07-27-2017 08:34
07-27-2017 08:34
What about adding walk to the Blaze?
Best Answer09-09-2017 18:12
09-09-2017 18:12
I cannot get that screen. I get one listing a few exercises, each of which I can open. When I do I can set it to "ignore" and that seems to shut it iff, but no bones options appear, and no "add new exercise" line appears at bottom of anywhere.
Best Answer09-09-2017 18:54
09-09-2017 18:54
@EllieJo do you already have 7 exercises selected? If so all your slots are filled. And you will need to swipe one off of the screen before one can be added.
Best Answer09-09-2017 19:20
09-09-2017 19:20
Best Answer09-09-2017 22:34
09-09-2017 22:34
@EllieJo what didn't work?
Holding the finger on an exercise and dragging it off the screen?
Or adding an exercise?
