Charge 2 very dim display
The display is really dim, is there a way to adjust the brightness?
9 REPLIES 9
I have the same issue -- when I am outside I need to find a shady spot on my jog/walk to see the current time
Mine is so dim I can barely see it in the dark. It happened while it was sitting unused for a couple of weeks.
Welcome on board @Stevers and @TFAussem! If your Charge 2 display is dim, I'd recommend restarting your Charge 2 by following these steps:
  1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
  3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display. Your Charge 2 will begin charging.
  4. Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
  5. Unplug your tracker from the charging cable.
If your tracker was purchased through a retailer, I'd recommend taking it back to the store to see what your options are.
When a tracker suffers damage while under warranty, you can contact Customer Support. Discounts and replacements depend on tracker model and other factors.
If there's something else you'd like me to assist you with, let me know.
Thank you, but I've tried all of those things.I purchased it direcly through the Fitbit site on 05/17/2017, so it's out of warrant by a few months now. Are there any other options I have, other than having to purchase another one?
Thanks for trying the restart I've provided @SteversI have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. Smiley Very Happy They'll be more than glad to tell you what your options are.
Point me out if there's anything else I can do for you in the meantime.
Thank you! I will
My Fitbit charge 2 had been working perfectly and worn daily. I stop wearing it a few months ago and battery died. I just recharged and very dim display. Tried the reset multiple times as suggested. Seems a little brighter sitting a a room with the lights off, but still hardly visible.
I can see the display with no problem when I am indoors or outside if it is totally overcast and no sun. I am unable to see the display if I am outside and it is either partly cloudy or sunny unless I find a tree or building where I am shaded completely from the sun. Checking the settings I see no option to adjust the brightness of the display.
Hi my Charge 2 is also very dim. Trued the fix but its still dim. Can you assist?
