04-15-2019
16:16
16:45
04-15-2019
16:16
16:45
I have a charge 2 which used to work on my phone, have recently changed phone and managed to get it to work, now it won't pair or sync or do anything, keep getting can't pair message, so frustrating, please help if you can
04-15-2019 17:15
04-15-2019 17:15
Hi I'm getting the same problem too.
I had my Fitbit off for about 4 months and I've tryed putting it on my new phone and can't get it to sync with it
Best Answer04-15-2019 17:44
04-15-2019 17:44
Didn't change phones or anything but mine hasn't synced since Tuesday, April 9th. Tried removing and re-adding it, re-installing the Fitbit app, nothing worked. My Android (Galaxy S8) won't even connect to it via Bluetooth now.
Best Answer04-16-2019 18:57
04-16-2019 18:57
I am having the same problem. My Charge 2 stopped syncing with my Moto X4 when my phone updated to the April 1 update of the app... their response was that my phone was no longer supported and "Since the tracker isn't syncing, we recommend using a different compatible device." I guess I'll have to find a new fitness tracker.
Best Answer04-16-2019 19:36
04-16-2019 19:36
Uh, seriously? Neither my charge 2 nor my S8 are old. If this is their response I'll just dumpster the Charge and not buy any more Fitbits.
Best Answer04-16-2019 19:52 - edited 04-16-2019 19:54
Apparently if your phone isn't listed here https://www.fitbit.com/devices it's not compatible. I'm SOL. I do see Galaxy S8 listed though, so maybe yours can be saved.
Best Answer04-17-2019 00:49
04-17-2019 00:49
