01-25-2019
12:49
17:54
01-25-2019
12:49
17:54
I bought a second hand Charge 2 but cant get it to sync with my phone app.I already have the app as I did have another watch but I deleted that one. So I can`t change the date or time. It does count my steps though. Any help would be great thanks.
01-25-2019 16:37 - edited 01-25-2019 16:39
Is your phone on the Approved Device List?
01-26-2019 01:22
01-26-2019 01:22
My charge 2 hasn’t synced since Monday. I think there might be an issue
01-28-2019 11:01
01-28-2019 11:01
@MarleneLundaahl @Sizzlez79 Welcome! Thanks for being part of our Community! Sorry to hear that your Charge 2 isn't syncing with your phone. As @SunsetRunner mentioned please check if your phone is compatible. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
@MarleneLundaahl on your particular situation it seems that you haven't setup your tracker so please follow these instructions.
Let me know how it goes!
Best Answer02-02-2019 11:44 - edited 02-02-2019 11:45
I’ve had my Charge 2 for almost a year and have had no issues until recently, like the last two week. I did get a new phone last year but it’s an iPhone 8 and I didn’t have any problems initially. I hesitate to remove it because it has warned me that removing the device will delete all information that hasn’t been synced. I’m in a step competition with my work and will be losing all that data
Best Answer02-02-2019 13:25
02-02-2019 13:25
I am also having troubles with my Fitbit Charge 2. It quit syncing to my phone yesterday at 5 pm. I can get it to sync to my computer but it will no longer sync to my phone. Nothing has changed and I am really frustrated.
02-02-2019 15:35
02-03-2019 07:05
02-03-2019 07:05
Try this. It’s from a older article I found. It didn’t work on mine but did work on my friends.
If it's not showing as a current device or the syncing procedure didn't work, I'd recommend doing the following:
Make sure all other bluetooth enabled devices are out of range when you do this.
02-03-2019 09:48
02-03-2019 09:48
Hey! It worked. Phew. I have been lost without my Fitbit. I tried every other combination from the other posts but that one did the trick. Thank you! 😁
02-03-2019 10:02
02-03-2019 10:02
Nothing has worked for mine....until now....power cycle your Charge 2. Once I did this I was able to sync.
02-04-2019 06:35
02-04-2019 06:35
I have a similar problem, first the charge 2 didn't sync (since january 10th). After trying everything I've read on the forums, I finally unpaired the tracker, reinstalled the app and so on...
Now I'm stuck in a loop, everytime I enter the 4 digits. After entering the digits, I get a "try later" message.
I tried 15-20 times, still the same.
I can't pair the charge anymore, no matter what I try.
I'm sick of it, because it's not the first issue. Every 2-3 months it's the same, but until now I always managed to get the charge working.
Is there a factory reset?
Best Answer02-04-2019 14:37
02-04-2019 14:37
Have you tried restarting it?
Best Answer02-04-2019 21:58
02-04-2019 21:58
Best Answer02-07-2019 07:54
02-07-2019 07:54
@rh_ @Carol9169 @Decrkrda It's great to see that you've visited the Fitbit Community!
@Sizzlez79 @Carol9169 happy to hear that your Charge 2 are syncing and thank you for sharing what you did to fix this as it may help other members in the same situation.
@rh_ @Decrkrda please try the suggestions in my previous post plus the ones shared by @Sizzlez79. You can also check the suggestions in the help article.
Best Answer10-24-2020 05:48
10-24-2020 05:48
Thank you so much --this worked perfectly!
