04-09-2022
01:45
10:23
AndreaFitbit
04-09-2022
01:45
10:23
AndreaFitbit
My charge 2 will not sync... What can I do?
Moderator edit: format.
04-09-2022 10:21
04-09-2022 10:21
Welcome to the Fitbit Community, @Kusheer. Thank you for letting us know that your Charge 2 won't sync.
I noticed that you already got in touch with our Support Team and that you have already received assistance.
Keep on visiting the forums.
Best Answer04-11-2022 00:16
04-11-2022 00:16
Can you tell me how you fixed this mine is doing the same
04-12-2022 07:52
04-12-2022 07:52
Welcome to the Fitbit Community, @beccyk1621. I´m sorry to hear you haven´t been able to sync your Charge 2.
Please follow the instructions of help article: Why won't my Fitbit device sync?
Best Answer04-13-2022 10:54
04-13-2022 10:54
Doesn't help. My Charge 2 won't stay in contact with my phone long enough to sync.
Best Answer04-13-2022 11:06
04-13-2022 11:06
Thanks for getting back to us and for letting us know that your Charge 2 won't stay in contact with your phone long enough to sync @Lilbiddy.
Do you get an error message when you try to sync? Which is your phone's model?
Best Answer04-13-2022 16:39
04-13-2022 16:39
@AndreaFitbit I'm using a Sony L4 running Android 9. Charge 2 is updated and app is latest version.
The phone takes a long time to pair with the tracker. Then it drops contact. Tracker has been reset and app reloaded. Bluetooth has been faffed about.
Strangest thing is that I can link to my Kindle fire which still has app version 2.63. If it wasn't for this now deleted version I would not be able to use my Charge 2 at all.
I think there's something off with the Bluetooth in the tracker. A couple of times a message came up about a wrong "pass code or pin number". I haven't the foggiest idea what that is referring to. The tracker will eventually drop contact with the Kindle but at least it links long enough to synch my data.
Any bright ideas ?
04-14-2022 07:54
04-14-2022 07:54
Thanks for getting back to us and for letting us know about your phone and what happens when you try to sync your Charge 2 @Lilbiddy.
The Fitbit app is compatible with most popular phones and tablets. To set up and use your Fitbit products and services, you must install the Fitbit app on a compatible device running one of the following operating systems:
Do you get the passcode message when you sync?
Best Answer04-14-2022 13:21
04-14-2022 13:21
If you read my post you will see I am running Android 9. My app version is 3.57 as provided by Play Store which states that the update is suitable for Android 8 and above. The Charge 2 doesn't have the ability to respond to messages etc. Really don't know why you think Android 10 is required.
As for the passcode I assume that is the 4 digit number required for installing the device. Yes I do get that.
So are you saying that your app is wrongly described in Play Store and that you have rendered my Fitbit useless without any prior notification? No exactly good customer service is it? The app update of 3.57 was sent to my phone..If it shouldn't have been then you have actually sabotaged my Fitbit. Another reason why older versions should remain available.
How do you intend to rectify your error?
Best Answer04-18-2022 06:16
04-18-2022 06:16
Andrea,
My FitBit app won't allow me to login. My Charge 2 stopped syncing last Tuesday. I have an iPhone SE. I can see the Bluetooth is connected to the Charge 2. I attempted to login to the FitBit app on my phone and it always gives me the "Oops, something went wrong." I removed the app and re-installed it a couple times. Did a force quit and disconnected from the Blutooth and then reconnected. I still just get the join/login page, and after entering my information, it gives me the "Oops" message.
Thanks!
-Art
Best Answer04-19-2022 11:07
04-19-2022 11:07
Thanks for getting back to us and for your feedback @Lilbiddy. I got the information about Android 10 here. I understand how frustrating this could be and reported this in order to correct Play Store information. We strongly recommend using Android 10 for best results but can still work with previous versions.
Thank you for reporting this @drartlee. Have you tried syncing your Charge 2 with a different device? Which version of the app does your iPhone have? Does your tracker have the latest firmware version?
