04-12-2019
08:51
11:08
04-12-2019
08:51
11:08
I bought a fitbit charge 3 special edition yesterday. I want to load a credit card into the wallet but i do not have a wallet tile
04-13-2019 09:59
04-13-2019 09:59
Welcome on board @Johhnny, it's nice to see a new member around! I'd recommend what my friend @N8teGee suggested.
I wanted to add here, that this may occur due because the customer's Country doesn't support Fitbit Pay.
If there are no banks in your country, you won't be able to see the Wallet tile in the Fitbit app. For a listed of supported banks/countries, visit www.fitbit.com/fitbit-pay/banks.
To see the Wallet tile in the Fitbit app, you need to set the Profile Settings Location in the app to your country of residence.
Let me us know the outcome, we'll be around!
Best Answer04-13-2019 00:36
04-13-2019 00:36
Hi @Johhnny, nice to see you in the community.
Have you made sure that your Charge 3 has been updated to the latest firmware version?
I would also suggest logging out of the fitbit app and then logging back in again. If the wallet tile still doesn't appear, it might be worth uninstalling and reinstalling the fitbit app.
Best Answer04-13-2019 09:59
04-13-2019 09:59
Best Answer10-13-2019 18:34
10-13-2019 18:34
hi MarreFitbit,
I've the same problem but the solution hasn't worked.
Have Charge 3, iPhone XS, both updated to latest software.
Wallet tile doesn't appear in Profile>Charge3>Account.
My location on the iPhone and FitBit are both set to Australia.
My bank and card are supported (both the bank's list says it is, and the FitBit list says it is. i.e. Westpac Bank)
Best Answer10-14-2019 13:58 - edited 10-14-2019 13:59
Hi there @brad_3, welcome to the Community Forums. Thanks for following the recommendations I've provided above in order to show your Wallet Tile.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Best Answer03-29-2020 07:17
03-29-2020 07:17
Hi I dont seen to have the wallet tile either?! Just bought and updated the charge 3 and my iPhone is all updated also?! Iv tried to do everything you have said on the thread but nothing?
Best Answer03-29-2020 14:33
03-29-2020 14:33
Hi Josie - Do you have “Charge 3” or “Charge 3 Special Edition”?
I found that only the latter has Fitbit Pay available on it and so purchasing a Charge 3 was a complete waste 😞
Best Answer03-29-2020 15:00
03-29-2020 15:00
Best Answer10-12-2020 13:36
10-12-2020 13:36
Greetings,
I open the app, select my image (top left) click on my name and that’s where it stops. I have uninstalled and reinstalled the app. But what makes this weird/ confusing/ frustrating is that not long ago I was able to add a credit card to my Fitbit.....I wanted to add another but am stuck....please help
Best Answer10-12-2020 14:12
10-12-2020 14:12
Hi johng1671 - what device are you using? Is it either 'Charge 3' or 'Charge 3 Special Edition'?
Best Answer07-08-2021 14:40
07-08-2021 14:40
Hi Marre,
I have charge 3, location is Canada, phone is Google Pixel 2 XL.
Tried to reinstall the app and reconnect the tracker.
Still I don't have the wallet icon.
Please advice.
Thanks
Best Answer07-08-2021 14:44
07-08-2021 14:44
Hi livar - please see the note above regarding wallet not being available for charge 3 - what device are you using? Is it 'Charge 3' or 'Charge 3 Special Edition'?
07-08-2021 14:54
07-08-2021 14:54
07-08-2021 15:18
07-08-2021 15:18
Therefore see the thread above - only the charge 3 special edition has Fitbit Pay available on it. Charge 3 does not.
07-08-2021 15:28
07-08-2021 15:28
Best Answer07-09-2021 04:34
07-09-2021 04:34
Hello everyone. @livar, @brad_3 Nice to see you around! @brad_3 Thank you very much for your great input!
@livar I appreciate the detailed information and the steps you've followed. At this time, I'd like to let you know that Fitbit Pay works with Fitbit Charge 4, Fitbit Ionic, Fitbit Sense, Fitbit Versa 2, Fitbit Versa 3, and editions of Fitbit Charge 3 and Fitbit Versa that contain an NFC chip. To check if your device supports Fitbit Pay: Fitbit Charge 3: remove the bottom band and look for "Fitbit Pay" printed on the end of the tracker.
For more information, I recommend visiting this help article: What should I know about Fitbit Pay?
Hope this helps.
11-19-2022 16:21
11-19-2022 16:21
It´s the same for me
Best Answer11-19-2022 17:00
11-19-2022 17:00
Hi Mbenitez68 - have you read the thread above about re: the false advertising by Fitbit ? What model Fitbit do you have?
