05-23-2021 18:45
05-23-2021 18:45
On the charge 3 the auto setting allows a higher maximum brightness level when the light sensor detects a bright environment. This maximum level is brighter than the 'normal' setting. I would request adding a setting for 'high' brightness and simply add the battery warning that is present on screen timeout as it would obviously adversely effect the battery life.
05-23-2021 19:13
05-23-2021 19:13
Welcome to the Fitbit Community, @Remov.
Thank you for your suggestion.
You are welcome to make a request in the Feature Suggestions board which is constantly monitored by our engineering team for future implementations. Once any update be available it will be communicated as soon as possible.
See you around.
