04-27-2020
06:59
11:44
04-27-2020
06:59
11:44
I am having a screen glitch on my Charge 3. The display will jump around, blink on and off, disappear and is unreadable. I have only had this Charge 3 since Christmas 2019. I have already shut down and restarted several times. Is there a fix for the screen glitch issues?
04-27-2020 10:15
04-27-2020 10:15
I’ve had the same issues for a few days now. Along with the glitches, my screen is has vertical lines across the face making it difficult to read.
Best Answer04-27-2020 10:26
04-27-2020 10:26
@Fishnfan my Fitbit was fine this morning and then I put it on to charge and it has the same vertical lines you are describing. I put it back on the charger and restarted it with no change. It does appear to be tracking correctly and I can kind of see the data through the lines. Hopefully it's just a bug they are fixing!
Best Answer04-27-2020 11:08
04-27-2020 11:08
I am having this same problem with my Charge 3. I tried the 15 second reset but problem continued. Charge 3 is syncing but screen unusable
