06-23-2020
01:35
09:46
06-23-2020
01:35
09:46
This will be my third attempt in as many days. Please will someone assist me.
my screen is flashing between clock and notification face, and vibrating. I have rebooted a number of times and it’s still doing this.
I have had it since April.
I need assistance please, or shall I write an honest public review about this issue?
06-23-2020 01:45
06-23-2020 01:45
Can I check that this is the restart procedure you have tried: Help article: How do I restart my tracker?
If it is, and it's not working, then it would suggest a hardware issue, possibly with the button. If that's the case then the user community is not going to be able to help and you would do better to contact customer support. If they can't fix it then they can check your warranty status and advise on your options. You can contact them via contact.fitbit.com
Best Answer07-05-2020 04:11
07-05-2020 04:11
Hello, I'm having a similar problem. My fitbit versa 3 keeps on vibrating and it is constantly on the payment page and notification on/off .
I tried many times the reboot 15 seconds when plugged in , but nothing happens. I live in Australia .
