04-10-2021 06:53
04-10-2021 06:53
The side button is not responsive, and somehow my Charge 3 has started it own workout, so I can't use the menu to reboot. Is there another way to reboot it? Also, it's not holding a charge for more than a day...wondering if it's already reached its end of life?
04-16-2021 07:24
04-16-2021 07:24
@Candlechix Thank you for following our suggested troubleshooting steps!
Since the inconvenience has persisted, I recommend contacting our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
See you around.
Best Answer04-10-2021 10:41
04-10-2021 10:41
Hello @Candlechix. Welcome to the community forums!
Thank you for the information and for the troubleshooting steps you've tried prior to posting. I'd like to let you know that the Charge 3 can be restarted by opening the Settings App on it, then tap About > Reboot Device, or by following the steps here: How do I restart my Fitbit device?
If that doesn't help, I recommend performing a long restart, you can do this, by following the steps below:
On a side note, there are some factors that could impact the battery life of your Charge 3. For tips about how to maximize it, please visit:
Can I extend my Fitbit device's battery life?
Hope this helps!
Best Answer04-11-2021 06:14
04-11-2021 06:14
Thanks for your reply! I have seen these suggestions in other posts. However, the button is not responsive so I can't push it to reboot. Also, there is a "workout" going on the watch, and I can't use the button to back out to the menu. Other suggestions? Perhaps I need to let the battery run out?
04-16-2021 07:24
04-16-2021 07:24
See you around.
