12-08-2020
09:55
14:28
RicardoFitbit
12-08-2020
09:55
14:28
RicardoFitbit
I walk mostly the same route every morning, same distance same times etc. Some mornings my active minutes are fab but other days it doesn't even register any, it seems every time I take part in the bingo challenge my active minutes are zero every day..something strangely wrong here. Im a premium member by the way as well.
12-08-2020 14:12
12-08-2020 14:12
Hi @Pad45, welcome to the Community Forums.
Thanks for bringing this to our attention and for the details that were shared in your post. To fix this uncommon situation, I recommend you to restart your Charge 3 and then learn more about how active minutes are recorded with the information that's specified on our help article: What are Active Zone Minutes or active minutes on my Fitbit device? and let me know if the issue persists.
I'll be here if further assistance is needed.
Best Answer12-09-2020 12:31
12-09-2020 12:31
I called about this last night. Rep took me through troubleshooting techniques. No change. I've been achieving over 20,000 steps each day but showing "0 active minutes". Hmmmm
20:33
16:59
12-09-2020
20:33
16:59
Welcome aboard @Momma-Michelle.
Thanks for sharing your experience on this thread. Just as mentioned in your post, our Customer Support team informed me that they already provided you assistance to resolve this situation. That said, I recommend you to contact them back if you require further assistance or if you have any additional questions about the outcome of your case.
I'll be here if you need anything else.
Best Answer12-14-2020 20:58
12-14-2020 20:58
This appears to be a persistent problem.and not a one-off problem. I too have a Charge 3, Premium, and none of my active minutes turn into Activity minutes in Bingo.
12-15-2020 13:05
12-15-2020 13:05
Hi, I have restarted my fit bit a good few times since my above ongoing issue, but still my active minutes seem to not be registering and its usually when I take part in a bingo challenge with other futbit friends, for instance last week I recorded 127,000 steps and around 156 floors but not one single active minute was recorded..now dont u find that a bit strange ? Everything else is brilliant, deffo an issue here as a few comments are showing the exact same problem guys
