01-30-2020
18:33
17:16
01-30-2020
18:33
17:16
I received the special edition for Christmas and while it worked for a week or two nothing works reliably anymore. I’ve tried all the troubleshooting steps.
01-31-2020 03:43
01-31-2020 03:43
It's great to see you around, @jmackma.
I will be glad to help you out with the issues you are experiencing with your Charge 3.
Let me know the outcome. 🙂
Best Answer02-03-2020 09:31
02-03-2020 09:31
So far my notifications are still working.
Should I expect issues if I sync both with my iPhone and then at night with my iPad? I use the iPad to set my alarm, check sleep stats, etc. I can stop doing that.
The alarm is still a concern (I know you're looking into it) but when I set one for 6am the next day it's almost like it turns itself off at midnight. (because it's off when I wake up in the morning)
The two critical features I need to work consistently are the alarm clock and the notifications otherwise I'll need to start looking for another brand.
Best Answer05-11-2020 15:20
05-11-2020 15:20
Hi Fitbit, this recurring alarm problem has been going now for years. Yes you keep saying your team are aware of the issue and are working on it - but how long should we wait? Are your developers so busy with new products that there is no resource to fix the older ones? I'd rather have a working alarm than all the mindfulness, nutrition and sleep messages you keep sending me! I'd get much better sleep if I wasn't worried about the alarm not going off in the morning. I'm getting close to tossing my fitbit in the bin and buying a different brand.
