07-12-2025 00:00
07-12-2025 00:00
Every time I wake up in the middle of the night and go back to sleep after an hour or so, I click "Enter Sleep." And then it goes wrong. When I click "End Sleep" when I wake up again, only the end time is displayed. The time I was awake has disappeared.
07-12-2025 15:59
07-12-2025 15:59
If you are telling it when you start and sleep and when you wake up, that is not needed or recommended. You should just let your tracker detect that by itself.
Best Answer07-13-2025 21:42 - edited 07-13-2025 22:01
Thanks for the advice. Problem: the tracker doesn't detect my second sleep. I have to enter it manually afterwards, and then the information isn't processed. So now it seems I have to choose between entering my second sleep beforehand or afterward 🤪
