01-13-2020 01:55 - last edited on 09-24-2020 19:06 by
01-13-2020 14:52 - edited 01-13-2020 14:53
Hi there @SheenaN, thanks for getting back and for the details you just provided.
If you want to open the tiles from Fitbit Today, this won´t be possible. You can only open apps on your Charge 3 by a quick tap. The tiles from Fitbit Today are the ones you receive by swiping up the screen. I am posting an image below for you to see what are they.
I hope this clarifies your inquiry. Let me know if you need further assistance. 😊
Best Answer01-13-2020 06:54
01-13-2020 06:54
You can try to perform a swipe up when your Charge 3 is showing the watch face. There, you should see some stats. Hope it helps.
01-13-2020 12:44
01-13-2020 12:44
Hi there @SheenaN, welcome to the Community Forums. Thanks for the details provided.
If your Charge 3 isn't opening the apps as described in the article: How do I navigate my Fitbit device's screen?, I'd recommend restarting your tracker by following these steps and then try opening the apps with a quick tap.
Thanks for your help @asiayeah.
Let me know if the recommendations work, I'll be around if you need further assistance.
Best Answer01-13-2020 14:44
01-13-2020 14:44
Best Answer01-13-2020 14:52 - edited 01-13-2020 14:53
Best Answer01-13-2020 14:54 - edited 01-13-2020 14:56
@SheenaN Also, if you see the infamous "Sleep not Tracked" in one of your tiles, it's "perfectly" normal. Most Charge 3 users cannot see their sleep stats on their Charge 3 but only available on the app itself. It is a well know defect. Thanks.
@MarreFitbit Please correct me if I am wrong.
Best Answer01-20-2020 01:27
01-20-2020 01:27
Thank you, I've got it now. Just have to look at stats on my app, which is fine. Thanks for your help
