Charge 3 battery draining immediately
Been having issues with my Charge 3 whereby the battery does not last more than a second. The watch just dies completely within a minute or less after charging it to100%. I have tried to troubleshoot and reboot, etc and nothing seems to work.
I also tried to check if the battery can be replaced but seems like that is not possible.
3 REPLIES 3
Hi @GMaharaj,
Thank you for all the troubleshooting that you've already done.  The next step is to contact Support via the link at the bottom of the page and ask them to help you administer a Battery Test.  Something is clearly wrong with the battery, and this test will help you diagnose the issue.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Hi @DramaQueenDiva
Thanks so much will contact them now
Hello @GMaharaj, welcome to the community forums! @DramaQueenDiva, it's great to see you around and thanks for your input!
If the response given by @DramaQueenDiva, has helped to resolve your inquiry,  I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a great day!
Wilson M. | Community Moderator, Fitbit.
