02-09-2020
09:28
14:21
02-09-2020
09:28
14:21
Taking my Charge 3 off the charger, green light was on, then flashing and would not turn off. Battery completely drained, Charge 3 is back on charger and does not appear to be charging, pressing the button on the unit does nothing. Item was purchased May 2019... so only 10 months... Anyone know what to do to fix?
Thanks
02-10-2020
03:14
07:20
02-10-2020
03:14
07:20
Welcome to the Community, @Nicegrump.
Thanks for troubleshooting this battery issue. If your Charge 3 isn't holding a charge, I recommend taking a look at the help article: Can I extend my Fitbit device's battery life? and follow the tips provided there. After following them, test your unit.
You can also perform a long restart by doing the following:
Let me know the outcome.
