11-09-2020
03:35
10:17
11-09-2020
03:35
10:17
@SarahP321 Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 3 draining its battery quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Best AnswerThis did not work. I plug it in and it immediately says 100% charged but I still leave it for a few hours. Within minutes of taking it off of the charger the watch is below 5% then off completely.
08:47
10:17
11-10-2020
08:47
10:17
@SarahP321 thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
06:40
10:17
11-11-2020
06:40
10:17
@Joe_V Welcome to the Community.
Let me help you with your Charge 3 not holding a charge and the heart rate sensor not working. For the battery issue please try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Regarding the heart rate sensor I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
