06-21-2020
04:41
09:49
06-21-2020
04:41
09:49
My charge 3 screen seems to have completely gone . Still buzzing when you press side button . Still connected to app and recording. Any help or ideas ? Thanks
06-28-2020 17:47 - edited 06-28-2020 17:48
Hello there @S444amw, welcome to the Community Forums. Thanks for the details provided in your post about your Charge 3's screen behavior. I'll be glad to help you.
In order for me to better assist you with this, please try the following suggestions:
I'll be around, keep me posted.
Best Answer06-28-2020 17:47 - edited 06-28-2020 17:48
Best Answer08-10-2022 20:35
08-10-2022 20:35
Hi, I’m jumping in on this conversation because I am having the same trouble. I tried to change the clock. Nothing. What’s next?
Best Answer08-11-2022 05:27
08-11-2022 05:27
Hey there, @BaileyAnn. Thanks for stopping by in the Community Forums. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer10-31-2022 23:58
10-31-2022 23:58
Plug the device into the charging cable.
While the device is plugged into the charging cable, hold the button down for 15 seconds.
Remove your finger from button.
Remove the device from the charging cable.
Plug the device into the charging cable again.
The smiley face icon appears on the screen.
Regards,
Will
Best Answer01-04-2023 09:49
01-04-2023 09:49
I’ve tried the instructions on how to remedy a black screen and none have worked. It is connected to Bluetooth; battery is full . Now what?
